Date/Time: Sat, 22 Feb 2025 18:20:51 +0000
Market by order - Order ID
View Count: 634
[2021-02-03 12:27:26] |
User411647 - Posts: 21 |
Dear support When will we be able to work with Order ID ?? thanks :) |
[2021-02-04 13:49:37] |
Yes you have access to this data through these ACSIL functions: sc.GetBidMarketLimitOrdersForPrice sc.GetAskMarketLimitOrdersForPrice We will document these as soon as we can. Make sure you are running an up-to-date version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-04 13:49:48
