Date/Time: Sat, 22 Feb 2025 17:29:28 +0000
tomasz nogowski
View Count: 435
[2021-02-03 12:10:14] |
User830812 - Posts: 4 |
Hi I reactivated my data feed after insufitient founds and deactivation but it seems like data is not floowing in my software. Could you please assist with that?
[2021-02-03 12:50:31] |
Make sure the symbols are set correctly using this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service And if you want to use the Sierra Chart Order Routing Service, then follow the instructions here beginning at step 9: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-03 12:52:14
