Date/Time: Sat, 22 Feb 2025 17:56:43 +0000
Bizarre data for CL today
View Count: 471
[2021-02-03 09:14:30] |
User303575 - Posts: 8 |
What is causing this price behaviour on the right? I checked other price chart sources such as tradingview and they don't mirror this price behaviour. http://www.sierrachart.com/image.php?Image=1612343525152.png |
[2021-02-03 09:33:59] |
You need to set the Continuous Futures Contract option to None: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options You cannot use a far forward non-active contract month, and keep this option enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-03 09:34:11
[2021-02-03 09:36:23] |
I see. I do wish to continue to use a continuous contract so should I select the contract that has an expiry in the next month or in the current month?
[2021-02-03 09:39:22] |
In this case you will want to use the March 2021 contract for the symbol of the chart. And if there any issues follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-03 09:39:47
