Date/Time: Thu, 06 Mar 2025 16:30:57 +0000
Filtering for Large volume activity
View Count: 2544
[2021-02-03 07:05:35] |
User432142 - Posts: 44 |
firstly thank you for larger volume trade indicator. it has become awesome indicator recently. *draw mode= Based on Total Ask Bid Difference Above Threshold *volume threshold= 5 for instance, the list of volume is shown on chart are 5,7,5,8,7,12,25,32,70,95 everything works fine. Is there anyway to filter only volume which is greater than 25. so it is shown 25,32,70,95 Because chart looks so messy and slow l couldn't figure out how to filter |
[2021-02-03 07:56:18] |
Yes. Refer to: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-03 10:20:49] |
it filters all studies, l just want to filter volume related of large volume trade indicator and see 25,32,70,95 instead of 5,7,5,8,7,12,25,32,70,95 even l tried to used the indicator volume at price threshold alert but it doesnt show as text |
[2021-02-03 12:20:06] |
In this case you just have to use a dedicated chart for the Large Volume Trade Indicator and no other studies.
[2021-02-03 12:44:36] |
l have already many chart, there is no way to add that feature for the Large Volume Trade Indicator? for example Lowest Quantity for Showing l guess l can not use for the Large Volume Trade Indicator as well. Study/Price Overlay Study: Using the Study/Price Overlay Study The following studies cannot be overlaid from one chart to another with the Study/Price Overlay study: Volume by Price TPO Profile Chart Numbers Bars Countdown Timer Market Depth Historical Graph (studies which display text only) |
[2021-02-03 14:51:09] |
John - SC Support - Posts: 38442 |
We are continuing to do some work on the Large Volume Trade Indicator and we will consider what you are looking for. Just keep in mind that we cannot make any promises on if it will be done or when.
[2021-12-29 11:59:39] |
Hi, is there any process for above request which mention in #3 |
[2021-12-29 14:58:03] |
We have not had a chance to get to this.
[2022-01-16 12:58:25] |
can you please add this feature which is mentioned above. l am really waiting this for long time and it will be good advantage for me and other traders. For this reason l use another platform for this feature
[2022-01-20 05:44:36] |
User19165 - Posts: 346 |
The above request would be really useful. Related to it, but a little bit different is can we further calculate the filter like we can with the T&S combine records with same time and type. For exchanges that are not able to use tape reconstruction, this can be a better than nothing approximation.
[2022-01-28 06:36:08] |
[2022-02-09 23:12:51] |
We have added a new Input for the Large Volume Trade Indicator called Do Not Display Values Less Than. When this value is set to a Non-Zero number, then the displayed values for the Large Volume Trade Indicator will not display any value less than the set amount. Keep in mind, this is not less than or equal to, so when you enter a value of 20, you will see values of 20 and above, but nothing less than 20. With the difference calculations it uses the same value as both the positive and negative values, so you can filter both sides. For example, if you enter a value of 20, then any number between -19 and 19 will not be displayed. This change will be in the next Pre-Release (v 2354). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
