Date/Time: Sat, 22 Feb 2025 17:31:17 +0000
Not Getting REAL-TIME Data
View Count: 498
[2021-02-03 06:51:16] |
Jonathan Fan - Posts: 2 |
I subscribed for the package 12 and Activate the CME Full package, so I can receive real-time data to all markets. However, after I follow the Instruction steps, I still see DELAYED on my charts. Here is the link to screenshot image: http://www.sierrachart.com/image.php?Image=1612334250660.png Please help me figure out how I can receive REAL-TIME DATA. Thank you, Jonathan |
[2021-02-03 07:54:48] |
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
