Date/Time: Sat, 22 Feb 2025 17:59:07 +0000
[Programming Help] - Global Settings >> Chart DOM Settings
View Count: 491
[2021-02-03 01:35:40] |
Bruce - Posts: 47 |
Chart Dom settings -Global view, not Configuration mode. how do I reset this so i can make changes. Thanks |
[2021-02-03 08:06:54] |
What specifically do you want to reset? For instructions to work with these new Settings Windows, refer to: Getting Started, Opening Charts and Basic Trading: Working with Sierra Chart Settings Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-03 08:07:02
