Date/Time: Sat, 22 Feb 2025 17:40:46 +0000
chartbook
View Count: 509
[2021-02-03 00:06:47] |
mario_80 - Posts: 1 |
Hi I am new to Sierra .I have some issues applying chartbook of my interest.It says Download Error...please find the attached picture.Is it becasue I am not connected with a broker data feed?? I opened demo account with AMP using mt5 platform I want to open account live account with AMP anyway and using your platform with denali feed.Where shall I start from?All this is a bit confusing Kind regards Mariusz Stanke |
[2021-02-03 13:02:33] |
Make sure the symbols are set correctly by using this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
