Date/Time: Sat, 22 Feb 2025 17:19:30 +0000
Problems with moving orders on DOM
View Count: 536
[2021-02-02 19:34:14]
User670350 - Posts: 19
Dear All;
I have problems with moving my orders on DOM. If I create the order and try to move it by couple of ticks this stupid icon appears and doesn't let me do it.
As you can see I disabled confirmations and also disabled them in Global Setting and it still doesn't work.
Any advice?
Thank you;
Andrew
imageDOM1.PNG / V - Attached On 2021-02-02 19:33:48 UTC - Size: 65.09 KB - 188 views
imageDOM_2.PNG / V - Attached On 2021-02-02 19:34:02 UTC - Size: 224.07 KB - 198 views
[2021-02-02 20:12:11]
Do not click on either the Quantity number or the X button of the order line. You need to click and drag elsewhere along the order line.
So you will need to widen the Trading DOM window.
