Date/Time: Sat, 22 Feb 2025 17:53:34 +0000
footprint
View Count: 522
[2021-02-02 17:06:12]
User491428 - Posts: 87
Hello I have a problem with my chart. sorry but my english is bad.
I trade with the footprint chart but in the YM it only shows the order in every second price. see photo which I have attached. have I overlooked something here in the settings?
imagefootprint YM.PNG / V - Attached On 2021-02-02 17:05:31 UTC - Size: 67.99 KB - 225 views
[2021-02-02 17:56:51]
John - SC Support - Posts: 38116
Most likely you have the Chart >> Chart Settings >> Volume At Price Multiplier set to a value of 2. If you do not need it set to a value other than 1, it should be set to 1. Refer to the information here:
Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu)
[2021-02-02 18:08:25]
it's set at 1. thats not the problem
imagechart settings YM.PNG / V - Attached On 2021-02-02 18:08:15 UTC - Size: 45.44 KB - 188 views
[2021-02-02 18:15:46]
It's on the Main Settings tab and it called Volume at Price Mult.. The image you show is of the Advanced Settings 2 tab.
