Date/Time: Sun, 16 Mar 2025 08:24:09 +0000
Commission on position line
View Count: 782
[2021-02-02 16:21:12]
User459170 - Posts: 262
Is there a way to include the commission on the position line?
[2021-02-19 04:03:39]
Yes. Refer to this setting:
Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu)
Date Time Of Last Edit: 2021-02-19 04:03:47
[2021-02-19 13:59:20]
I have this already set up and it works on the DPL beautifully, but on the position line (on the chart where we have the stop loss line and order line ) it doesn't seem to be showing. Thanks so much.
[2021-02-19 17:40:50]
Are you wanting the commission to affect the Position Average Price or the profit/loss value on the position line?
[2021-02-19 18:53:48]
The profit/loss value on the position line and on the stop line. Right now it gives the p/l on these lines without factoring in the commission although it factors in the commission on the DPL on the DOM. Is there a way for it to reduce the commission from the p/l on these lines? Thanks so much for your help.
[2022-08-12 19:17:19]
Hi, I was wondering if you can help me with the above question please, thank you.
[2022-08-12 19:50:33]
John - SC Support - Posts: 38678
There is not an option to show the Profit/Loss on the Position Line including the Commissions.
