Date/Time: Sat, 22 Feb 2025 17:21:31 +0000
Оплата и подключение к CQG
View Count: 515
[2021-02-02 16:14:16]
User463528 - Posts: 1
Я был подключен к Вам через брокера AMP Global Clearing LLC на простую версию (бесплатно) , потоки ордеров были подключены через CQG. Сейчас я не могу запустить sierra chart котировки CQG ,хотя я подключался в AMP котировки цен и дата фид через CQG. Что мне делать, как подключится к Дата фид и потоку ордеров???
[2021-02-02 16:36:06]
John - SC Support - Posts: 38116
From Google Translate:
I was connected to you through the broker AMP Global Clearing LLC for a simple version (free), order flows were connected through CQG. Right now I cannot launch the sierra chart of CQG quotes, although I connected to AMP price quotes and date feed via CQG. What should I do, how to connect to the Date feed and order flow ???
First, we want to make sure that you are aware that we are no longer providing historical data for CQG. Therefore, if you are getting the Real-Time data, but not getting historical data, then you would need to talk with your broker about getting more historical data for CQG. Or you could use our Denali Exchange Data Feed.
If you are not getting any real-time data when connected, then we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
