Date/Time: Mon, 25 Nov 2024 17:27:38 +0000
Bid/Ask, Up/Down Tick and Volume
View Count: 1829
[2014-02-24 18:33:12] |
User23815 - Posts: 210 |
Could you explain to me the difference in these terms? Does one represent the market orders, while another the limit orders? Or something else? Thanks
[2014-02-25 01:50:42] |
Some of this is defined here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#Definitions Bid and Ask do represent the limit orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
