Date/Time: Sat, 22 Feb 2025 17:56:59 +0000
data en vivo
View Count: 455
[2021-02-02 15:59:31] |
User968194 - Posts: 2 |
hola buenas noches, me comunico por este medio por que me he intentado conectar a la plataforma pero al abrir sierra, no me conecta la data,y no he podido realizar los trabajos, quedo atento,gracias.
[2021-02-02 16:20:33] |
John - SC Support - Posts: 38116 |
From Google Translate Hello good evening, I am communicating through this means because I have tried to connect to the platform but when I open the saw, the data does not connect me, and I have not been able to carry out the work, I stay tuned, thank you.
The account that you have posted from is Expired. If this is the account that you are trying to use, then that would be why you are having a problem. Follow these instructions to renew access: Sierra Chart Purchase and License Information: Renewing Access If you have a different Sierra Chart account, then you would need to post from that account. Go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
