Date/Time: Sat, 22 Feb 2025 17:50:34 +0000
No Sync whit exchage
View Count: 457
[2021-02-02 15:57:03]
Joperman - Posts: 20
Hello Good afternoon, I have a problem, the Denail data with the CME data is not synchronizing, I have a delay of about 10 minutes, yesterday I spoke with my broker company and they activated them, but they still do not work thanks
[2021-02-02 16:17:25]
John - SC Support - Posts: 38116
Your setup looks good.
Check to make sure that the setting File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. If it is not, then set it to Yes and reconnect to the data feed following these instructions:
If the option is already set to Yes then we would need to see your Message Log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-02-02 16:19:27]
Thank you very much John!! have a great day
