Date/Time: Tue, 13 Oct 2026 12:18:23 +0000
Stop limit order - value in the brackets
View Count: 785
| [2021-02-02 15:31:53] |
| User58008 - Posts: 32 |
Hello, I have a question to the stop limit order - when I put it into the market, I can see two values - one that I set through the trading window and one that is in the brackets, now for example a one point higher than the value set by me. Could you please explain to me what the value in the brackets stands for? Is it some kind of a slippage? Is there any similar order type that will fill my position on the exact price I am demanding? Thanks |
| [2021-02-02 16:10:49] |
| John - SC Support - Posts: 48184 |
The value in the parentheses is the Limit value. Refer to the information here: Order Types: Attached Stop Limit Order Inputs (Trade Window >> Targets) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
