Date/Time: Sat, 22 Feb 2025 17:51:02 +0000
Keeping trading lock on
View Count: 564
[2021-02-02 15:14:11] |
HenKer - Posts: 8 |
hi all I wanted to find out it it's possible to keep the trading lock on after it's been activated without being able to just switch it off manually? At the moment when the trading lock comes on (e.g. by hitting global loss limit) you can just go into the Global Profit/Loss Management settings and un-tick 'lock after positions flattened'. For the weak-willed amongst us there's a temptation to just switch off the lock and keep trading. Is there a way to keep the lock on once it's been activated so it can't be switched off? |
[2021-02-02 15:58:58] |
No. When our direct CME routing is available this will be supported on server side.
[2021-02-02 16:07:18] |
HenKer - Posts: 8 |
Thank you! When is direct CME routing likely going to become available?
