Date/Time: Sat, 22 Feb 2025 17:20:49 +0000
Vertical displacement - Draw style -
View Count: 827
[2021-02-02 03:25:30] |
aelagha - Posts: 31 |
Hi there, is there a way to add a vertical displacement for symbols drawn by studies on top or bottom of bar? i.e. using Inside Bar study, I can place a point or an arrow on top or bottom of bars. However, if I add another study, i.e. Narrow Range, and do the same, the points will be on top of each others. Can I add a vertical displacement? thx
[2021-02-02 15:39:09] |
John - SC Support - Posts: 38116 |
There are some studies that have an offset built into them and some that do not. The easiest solution is to use the Study Subgraph Above/Below Bar as Text study, which does include an offset, to display the data from the other studies that do not support the offset. Refer to the information here: Study Subgraph Above/Below Bar as Text Another option would be to modify the study you are interested in to add the option for an offset. The Inside Bar study, for instance, has the code available in the Studies.cpp file that is in the ACS_Source directory under the main Sierra Chart installation directory. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-03 04:07:11] |
awesome. thx
