Date/Time: Sat, 22 Feb 2025 17:29:37 +0000
Week of Month
View Count: 487
[2021-02-01 23:01:57] |
User820318 - Posts: 40 |
Is there a straightforward way to identify the week of the month using ACSIL. For example say I only want to execute some commands on the 2nd week of every month. |
[2021-02-02 21:57:55] |
No, you would have to work this out. You can certainly determine the day of the week. Refer to this page for the available Date-Time functions: Working with the SCDateTime Variables and Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
