Date/Time: Sat, 01 Mar 2025 15:54:41 +0000
Adding Current Traded total volume (without adding an additional column on DOM)
View Count: 1531
[2021-02-01 22:14:30]
Deucalion - Posts: 31
Hi Guys, This is a really important feature for me that I need -
In Jigsaw the current traded volume can be added on top of an existing VBP (colored red for offered and blue for bid, white for in between) with number overlaid on profile as shown below. THis feature does not exist in Sierra DOM, I have to add an extra column on DOM to do this - please can you add this feature. TIA
Date Time Of Last Edit: 2021-02-01 22:16:02
image2021-02-01_17-00-05.png / V - Attached On 2021-02-01 22:13:40 UTC - Size: 192.24 KB - 496 views
[2021-02-02 14:46:58]
We will follow up on this as soon as we can.
[2021-02-02 19:43:01]
What does that particular current traded volume represent? The volume of the last trade? The volume since the last reset at each price level.
[2021-02-02 20:23:58]
Its volume of last trade.
Would this also be possible on the chart DOM and not just the trading DOM?
[2021-10-09 20:18:11]
indigominds - Posts: 6
This would be an amazing addition to the sierra charts trading DOM. Great suggestion! I look forward to the implementation of this. This would make it so much easier for traders to keep track of the volume flow.
[2021-10-11 15:47:18]
NotIll - Posts: 118
It would also be great if it wouldn't at least obscure the profile shape.
This goes for all such features such as last traded etc
[2021-10-11 16:23:38]
Spartan79 - Posts: 54
It's Cumulative Last Size column. Now it's in its own separate column.
This feature is already sort of in SC in Current Traded Total Volume with Cumulative Last Size.
The only difference is that Current Traded Total Volume, the Volume Profile can't be color customized like VbP study. And it only shows volume from the point you have your charts up and running.
image2021-10-11_11-07-36.png / V - Attached On 2021-10-11 16:16:41 UTC - Size: 82.47 KB - 406 views
image2021-10-11_11-08-27.png / V - Attached On 2021-10-11 16:16:49 UTC - Size: 40.8 KB - 330 views
