Date/Time: Sun, 23 Feb 2025 02:27:46 +0000
CME Ethereum Futures
View Count: 702
[2021-02-01 19:48:05] |
prada_23 - Posts: 1 |
Hello, I saw that Sierra supports CME's Bitcoin Futures. That is great, but the CME is just now adding Ethereum Futures (another crypto asset) and I was wondering if this is something that will be added to Sierra. Unlike Bitcoin, it is an asset that is just starting catch the institutional attention it deserves. CME-ETH Futures coming Feb 8th, 2021. Thank you for your time. |
[2021-02-02 02:30:34] |
We will set up support for this.
[2021-02-08 14:59:44] |
TraderX13 - Posts: 8 |
I am not able to find the symbol - is this broker controlled?
[2021-02-08 20:23:30] |
User181601 - Posts: 25 |
same here, tried and looking to know more Thanks
