Date/Time: Sat, 22 Feb 2025 17:25:00 +0000
Outrageous fees for Advantage Futures + EUREX + TT FIX
View Count: 680
[2021-02-01 16:07:07] |
mazzy /| blast - Posts: 54 |
I’ve asked Advantage Futures to be setup for EUREX and SC + own TT FIX order routing They ask for all these extra fees, recurring monthly - $250 MAP fee - 50 EUR connectivity fee - 12 EUR distribution fee - 11.90 EUR market data fee (I’d use Denali instead) Is this correct ?! |
[2021-02-01 18:23:39] |
John - SC Support - Posts: 38116 |
The only thing we can say is that some brokers charge for these fees and some do not. The only one we know for sure that does not charge these fees for using the Sierra Chart Order Routing Service with EUREX is AMP. But you can take a look at other brokers and see if you can find another option. Refer to the partial list of brokers in Step #2 of the Setup Instructions for the Sierra Chart Order Routing Service here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-01 19:49:55] |
In the case of trading EUREX you would need to go through AMP or use the supported CQG trading pplatform service with Sierra Chart. When it comes to EUREX market data, you definitively will want to use our new upcoming EUREX data feed documented here: New Upcoming EUREX Full Order Book Data Feed (Now Available!) You will not want to get this anywhere else and you to have no obligation to pay for market data fees anywhere else when using our data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
