Date/Time: Sat, 22 Feb 2025 17:23:06 +0000
Datafeed
View Count: 613
[2021-02-01 16:05:03]
Alexandra Bageli - Posts: 7
good day,
1. I am with ninja brokarage Phillips Capital and use the data feed CQG.
I use Sierra data live with CQG ..
Unfortunately no historical data is loaded ... only the current contract month.
now my question is can i connect denali data feed to ninja brokerage (phillips capital)?
if so what exactly do i have to do?
can I use sierra with two different datafeeds at the same time?
once with cqg and via new instance with SC datafeed?
[2021-02-01 18:19:50]
John - SC Support - Posts: 38116
First, we want to point out that you are not currently using any data from Sierra Chart. All of your data is coming from CQG at this time. Which is why you are not getting historical data and can only view the current contract month.
You can definitely use the Denali Exchange Data Feed. Since you are already connecting to CQG, you will automatically validate your futures trading account for the CME Group so you will qualify for the Non-Professional exchange fees. Refer to the information here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
As to using Sierra Chart with two different data feeds, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Refer to the following information on the Denali Exchange Data Feed:
Date Time Of Last Edit: 2021-02-02 22:19:07
[2021-02-01 19:25:31]
Thank you for your quick response,
now I see that you have extended your service and offer Sierra with Denali Datafeed as a package ..
11.Advanced for $ 56 is interesting for me, is this package with order routing service?
now I used CQG data through Ninja Brokerage (Phillips Capital),
how does it work then that Denali connects to my ninja brokerage? will I still need my CQG feed?
I currently have 2 CQG feeds, one for Ninja Trader and one for Sierra Chart ..
hope that it is understandable. :-)
[2021-02-01 21:17:04]
Ninja does not support the Sierra Chart Order Routing Service. Therefore, if you are staying with Ninja for your broker, then you will need to continue to use CQG for your Trading Service. But you can change to package 11 and get your data through us.
[2021-02-02 22:17:49]
You can use the Denali Exchange Data Feed with CQG in a single installation of Sierra Chart. Refer to:
Date Time Of Last Edit: 2021-02-02 22:18:14
