Date/Time: Sat, 22 Feb 2025 17:41:07 +0000
Strategy on renko charts
View Count: 970
[2021-02-01 15:49:35] |
User410207 - Posts: 2 |
I want a strategy which use on 1 sec timeframe or on live tick price, i need help regarding that, with custom brick size. I’m ready to pay for your fees and all if you can help me with it, i want to try it first on trial
[2021-02-01 18:06:11] |
John - SC Support - Posts: 38116 |
We are not understanding exactly what you are wanting. Do you need help with how to setup a Renko chart, or are you looking for help with one of the Sierra Chart Automated Trading options, or are you looking for help with a custom Automated Trading Strategy?
[2021-02-01 19:07:36] |
I need all, help in setting up a renko chart and setting up a strategy its very simple i dont how to do it as I’m mew to your charts and then set it on automatic trading. Tell me the price i need to pay for all this
[2021-02-01 20:59:06] |
First, refer to the following for how to get started using Sierra Chart charts: Getting Started, Opening Charts and Basic Trading Then refer to the following for information on Renko Bars: Renko Bar Charts And finally, refer to the following regarding Automated Trading using the Spreadsheet Study for Trading: Spreadsheet Systems, Alerts and Automated Trading: Creating a Trading System for Automated Trading For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
