Date/Time: Sun, 09 Mar 2025 01:40:40 +0000
[Locked] - can not use proxy
View Count: 3281
[2021-02-01 15:44:51] |
User547840 - Posts: 5 |
i have updated to the latest verison. and i try to use proxy setting, it shows following problem. How can i solve it? https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=47561 |
[2021-02-01 20:18:47] |
Regarding the error message from the proxy server, refer to: HTTP Communication Errors That proxy server is not compatible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-27 23:23:25] |
Are you having an issue logging into Sierra Chart through a proxy server? There were some invalid posts in this thread, which now have been deleted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
