Date/Time: Sat, 22 Feb 2025 17:16:56 +0000
Global P&L + Trade Only Symbol + calculations
View Count: 651
[2021-02-01 14:17:13] |
User156295 - Posts: 104 |
Hello I set Global PL to flatten with loss trigger value at -500$. Opened position as the first trade during a day - chart with Dax "as the main" and mini-Dax as "Use as trade only symbol" checked. Got flattened due to set Global PL but on the value of -$140. Where should I look for to know why it happened. Maybe it calculates Global PL only for Dax even if mini-Dax is set as Use as trade only symbol. Please give me some guidance where should look for deeper. Thank you. Date Time Of Last Edit: 2021-02-01 14:26:15
[2021-02-01 20:21:55] |
You should read over the Introduction section here for information about this: Global Profit/Loss Management: Introduction Also check the Currency Value per Tick for the chart you are trading from: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) You can also have a look at the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-01 20:22:57
[2021-02-01 21:10:33] |
- the most important thing to check there was if there were any trades before and it is ok as it was the first one during a dayGlobal Profit/Loss Management: Introduction Also check the Currency Value per Tick for the chart you are trading from:
- checked and for miniDax it is set to 5 so this is correctlyChart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) You can also have a look at the Trade Activity Log:
- checked and it was saying that it was flattened due to global net loss limit setTrade Activity Log: Viewing Historical Trade Activity Where else should I look for this devil... |
[2021-02-02 07:26:36] |
- checked and it was saying that it was flattened due to global net loss limit set Copy and paste here that particular line in the Trade Activity Log so we can look it over and any other surrounding lines above and below that are related.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-02 07:26:50
[2021-02-02 07:46:13] |
Yes, pls find as enclosed with the lines.
Date Time Of Last Edit: 2021-02-02 07:46:33
[2021-02-02 22:00:56] |
The -650, is based upon the the Daily Net Profit/Loss for all of the symbols being tracked as explained in the documentation. From our position, we have no ability to know what the data that was used in that calculation. You have to look at it through the Trade Statistics for Charts tab at the time: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
