Date/Time: Sat, 22 Feb 2025 17:17:31 +0000
Point Figure Chart setting
View Count: 688
[2021-02-01 13:55:45] |
MrShort - Posts: 1 |
Hi, I'm new to Sierracharts and I really like it! So many great options to configure TPO and footprint charts to your own flavor, awesome! Still one thing I can't figure out: When I setup a Point and Figure chart with a box size of 2 ticks and a reversal of 3 boxes it creates a new 'x' (box) on top of the last 'x' (box) when the price increases with 2 ticks. How can I change this behavior that it creates a new 'x' (box) as soon as the price increases with 1 tick above the previous 'x' (as soon as the price rice's into the new box 'x' I would like the box to be drawn)? Thank you |
[2021-02-03 12:29:52] |
This is not supported. Otherwise you will want to use a box size of 1 tick and not 2 ticks. Refer to the information here: Chart Settings: Point and Figure Bar (Intraday Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-03 12:30:16
