Date/Time: Sat, 22 Feb 2025 09:29:13 +0000
R Trader stuck at Waiting for history connection
View Count: 1383
[2021-02-01 11:41:03] |
User97684 - Posts: 136 |
Hi, Pls help - R-Trader is not able to load up, I have all data bundles from Denali, is it sth to do with 01 - Feb? Thanks |
[2021-02-01 12:05:23] |
No, this is completely unrelated to Sierra Chart.
