Date/Time: Sat, 22 Feb 2025 09:25:22 +0000
Vertical Scroll
View Count: 1315
[2021-02-01 10:51:45]
User401505 - Posts: 2
Good morning,
on Sierra Chart platform I can't find the setting to scroll in vertical direction the chart. Can you help me.
Regards
Andrea
[2021-02-01 11:45:43]
User609527 - Posts: 2
Same problem here. Horzizontal scrolling and moving is no problem. I can't move the chart vertically. Can't find how to fix this
Date Time Of Last Edit: 2021-02-01 11:46:31
[2021-02-01 11:57:22]
Found it. Use option interactive scale move Chart Scale and Scale Adjusting: Interactive Scaling
[2021-02-01 11:59:23]
I will try.
Thank you
[2021-02-01 12:48:08]
This is explained here:
Chart Scale and Scale Adjusting: Interactive Scale Move - Move Scale Up and Down
