Date/Time: Sat, 22 Feb 2025 09:31:33 +0000
[User Discussion] - Styling number bars
View Count: 1339
[2021-02-01 10:13:58]
heyhey - Posts: 11
Hello
I followed a tutorial on YouTube on Number Bars and my chart currently looks like Image sc1 but I'm trying to get the candle in
the middle of the Bid x Ask similar to image sc2
If anyone can help?
Regards
Date Time Of Last Edit: 2021-02-01 10:15:02
imagesc1.GIF / V - Attached On 2021-02-01 10:12:09 UTC - Size: 8.03 KB - 362 views
imagesc2.GIF / V - Attached On 2021-02-01 10:12:18 UTC - Size: 6.02 KB - 347 views
[2021-02-01 10:33:24]
www.emojitrading.com - Posts: 5
You can use Study/Price Overlay to overlay the main price graph (from the same chart!) into Chart Region 1 where your numbers bars are. Disable Inputs 11 & 16. Set the Graph Draw Type (Subgraphs tab) to Candlestick Bars. Then play around with the width of the candlesticks.
Date Time Of Last Edit: 2021-02-01 10:33:54
[2021-02-01 11:34:31]
heyhey - Posts: 11
Great thank you, almost there but how do I set the width of the candles as I can't find it?
Thanks again
[2021-02-01 11:38:13]
Graphics Settings: Chart Bar Widths
Can be applied as Graphics Settings - Chart (most probably what you want) or global.
[2021-02-01 13:45:58]
heyhey - Posts: 11
Thank you for the help,
pretty much have what I want now just wondering how I save this now as my template for all charts?
imagesc3.GIF / V - Attached On 2021-02-01 13:45:54 UTC - Size: 187.62 KB - 347 views
[2021-02-01 13:52:30]
Study Collection. Well documented.
