Date/Time: Sun, 23 Feb 2025 08:40:32 +0000
DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y_RIGHT_ALIGNED
View Count: 664
[2021-02-01 10:03:59] |
User311344 - Posts: 142 |
Hey, We have now DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y drawstyle and DRAWSTYLE_CUSTOM_VALUE_AT_Y_RIGHT_ALIGNED. Is there any chance you could add DRAWSTYLE_CUSTOM_VALUE_AT_Y_RIGHT_ALIGNED but with TRANSPARENT text? Something like DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y_RIGHT_ALIGNED Thanks in advance!!!!!! |
[2021-02-02 09:57:09] |
It would be really helpful and Im sure it's a quickie for you, cause there are similar draw styles already. Just this new combination of alignmenent and transparency. Thanks!
[2021-02-03 14:41:13] |
Hey any chance to add that draw style? Thanks
[2021-02-04 13:37:01] |
Yes we will look into this.
[2021-02-04 18:08:04] |
Awesome!!!!!!!
[2021-02-12 12:55:10] |
Any chance to add that drawstyle soon? Thanks!!!! EDIT: It's already there in 2228!!!! Thank you!!! Date Time Of Last Edit: 2021-02-12 14:58:57
