Date/Time: Tue, 26 Nov 2024 10:30:52 +0000
Reset Charts
View Count: 708
[2021-02-01 02:42:45] |
SADRIU Driton - Posts: 6 |
je souhaiterais remettre les paramètres par défaut de mes Charts. jai fais plusieur mauvaise manipulation pourriez vous m`aidez ??? Merci Cordialement Driton |
[2021-02-01 05:52:29] |
Flipper_2 - Posts: 57 |
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File
[2021-02-01 05:56:38] |
There is not a way to reset the charts unless you just create new ones. You can reset Sierra Chart to a default state following the instructions here: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-05 02:26:34] |
RobTrader85 - Posts: 1 |
Hi. How can I go completely back to the factory settings like when you open sierra for the first time. I made some changes to my footprint chart and I would like to have it as before but I tried uninstall, erase folders, everything and still is the same. Thanks. Date Time Of Last Edit: 2023-12-05 02:28:15
[2023-12-05 16:37:00] |
John - SC Support - Posts: 36286 |
If you are continuing to open the same Chartbook, then you are going to get the same result. You need to start a new chart (or a new chartbook) in order to get the chart into a "default" state.
