Date/Time: Tue, 04 Nov 2025 18:18:16 +0000
Scale X & Y Contant Relationship greyed out
View Count: 3149
| [2013-04-19 11:06:55] |
| KhaosTrader - Posts: 128 |
Hi, I am trying to use the x & y constant relationship but its greyed out, I have the level 5 package subscription.... How can I enable it? |
| [2013-04-19 17:51:37] |
Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ConstantRelationship Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-04-19 20:15:30] |
Ok, what chart types are Constant Range Scale Range types?
| [2013-04-19 20:19:12] |
Constant Range Scale Range types are documented on that page.
