Date/Time: Sat, 22 Feb 2025 17:46:10 +0000
[Programming Help] - Pettern Candle Stick Finder
View Count: 788
[2021-02-01 00:39:10] |
User215195 - Posts: 2 |
Hi I am having trouble entering an automated trade correctly using the candlestick pattern finder. I'm using both the "Spreadsheet system for trading" and the "candlestick patterns finder" study. I want to enter a trade one tick above the hammer when it is formed. I figured it would do this automatically once this condition is met but it is entering the trade lower when it is formed. See the attached figures. I have a 5 tick range bar chart. Is that throwing it off? |
[2021-02-02 00:06:05] |
Sawtooth - Posts: 4174 |
One possible reason: - If you have 'Signal Only On Bar Close (K,M)' set to No, a Hammer may occur intrabar on a range bar, triggering an entry at an unexpected price. |
