Date/Time: Wed, 16 Sep 2026 17:56:26 +0000
chart auto scrolling
View Count: 1527
[2021-01-31 12:45:57]
User563205 - Posts: 9
I am experiencing a strange behavior regarding the auto scroll feature. I am using multiple chartbooks each with 5 windows/charts open that are simultaneously updating (green number lower right). Even without manually touching the slider on any of charts (I am just switching between them/clicking on tiles below) sometimes the green number turns red.... even when I am not touching anything and literally staring at one particular chart.
I am aware of the functionality
"To go to the end you can press the END key on your keyboard or select Chart >>Go to End of Chart."
But this is always not enough because I realize too late what happened and the setup is already lost.
[2021-02-01 13:27:33]
Refer to:
Working With Charts: Charts Unexpectedly Scroll Back and Change Fill Space Amount
[2021-02-01 13:52:07]
Thanks for the suggested solution - actually, I have this option unchecked already. Can it be because of something else?
[2021-02-01 14:43:27]
Not that we can think of. This is not something we have observed. Or heard about from other users.
Maybe it is caused by a particular study. Studies do have the ability to scroll charts. Otherwise, not really sure.
Set this setting to No Scroll Wheel Support :
General Settings Window: Scroll Wheel (Global Settings >> General Settings >> GUI >> Scroll)
Maybe your scroll wheel is inadvertently giving signals.
Date Time Of Last Edit: 2021-02-01 14:43:50
[2021-02-01 15:24:05]
Will try and observe the results. Thanks.
