Date/Time: Tue, 26 Nov 2024 13:39:11 +0000
[User Discussion] - Alert For Numbers Bar When Individual Tick level > 100
View Count: 1559
[2014-02-24 15:32:15] |
User59082 - Posts: 7 |
Hi, I'm looking for a way to get an alert to sound every time a numbers volume on either the bid or the ask goes over 100. I've worked out how to do it when the volume of the entire bar goes over 100 on either the bid or the ask, but I'm only interested in getting an alert when any specific price level on either the bid or the ask has a volume greater than 100. For example if a numbers bar was: 0 | 1 15 | 44 12 | 50 3 | 34 103| 22 <-- Alert 33 | 1 13 | 44 12 | 101 <-- Alert 11 | 63 Is this possible? If so what is the formula? Thanks, Andy |
[2014-02-24 23:30:36] |
Sound alerting is not supported with the Numbers Bars study, but highlighting the kind of criteria you are looking for is supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-24 23:30:53
[2014-02-25 00:49:56] |
ganz - Posts: 1048 |
User59082 FYI: http://www.sierrachart.com/supportboard/showthread.php?t=37616 https://www.bigmiketrading.com/sierra-chart/29007-ofa-sierra-chart.html |
[2014-05-15 12:58:16] |
User82828 - Posts: 44 |
Hi, it would be nice if Sound alerting is supported within the Numbers Bars Old study, every time a numbers volume on either the bid or the ask goes over 100, for example. What do you think when this feature can be implemented for the profs ? ;-) |
