Date/Time: Sat, 22 Feb 2025 09:33:30 +0000
Message Log Sent - Failed to get the function address ...
View Count: 514
[2021-01-30 19:11:53] |
User716258 - Posts: 7 |
Great product! Love it. Thought I'd send this minor bug to you. Added 2 instances of ATR study to chart. Set to 55 and 200, attached to price chart 1, hide study, so that I only see the calculated values in the quote bar. Happens on any chart, any timeframe. Look at the bottom of the log, "Failed to get the function address ..." The study seems to be working fine. Sent log to you via "Send Analysis". Have a great day! |
[2021-01-31 01:52:51] |
Update Sierra Chart to the current version following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-31 02:38:23] |
That fixed it. :)
