Date/Time: Sat, 22 Feb 2025 09:38:19 +0000
Delta number per bar only?
View Count: 926
[2021-01-30 18:03:46]
HeyUgly - Posts: 251
hello , pic attached,
i run the VbP study as delta numbers, it calculates the overal session as it goes on per level
is there a way to just run this study so it just shows the current candle range delta lvls?
like say im running a 30min candle i just want to see that candles range only and only that candles delta lvls?
and then when the next candle opens we reset and i just see the next candles delta lvls?
imageyo.png / V - Attached On 2021-01-30 18:02:57 UTC - Size: 11.02 KB - 279 views
[2021-01-30 18:21:45]
and my 2nd question, being that i have to adjust my vol mult all the time on number bars to reflect the imbalance i wast to see, is there any way to change the "tick per volume bar" so when i change the "vol multiplier" in my chart settings , the other will change with it? everytime i have to change 1 i have to change the other to match it. would be really handy to be able to link these as i constantly have to adjust vol mult to reflect the imbalance i need to see in the price action
Date Time Of Last Edit: 2021-01-30 18:27:32
imageyo.png / V - Attached On 2021-01-30 18:21:38 UTC - Size: 51.13 KB - 189 views
[2021-01-30 20:02:19]
Ackin - Posts: 1865
question 1)
Custom Study:
VbP ID: Numbers
Library Free (2020)
imagevbp num2.png / V - Attached On 2021-01-30 20:00:43 UTC - Size: 32.85 KB - 234 views
[2021-01-31 16:34:12]
cheers for this , i registered this morning waiting for activation
[2021-01-31 17:14:39]
Ackin - Posts: 1865
Registered ..... In the email you have a link to download free libraries. The study is new, so if you have any suggestions on how to improve, then write directly there on the forum in the Suggestions section ....
