Date/Time: Sat, 22 Feb 2025 09:19:43 +0000
Needed extra support on setting up please
View Count: 571
[2021-01-30 15:58:32] |
User854740 - Posts: 1 |
Hello, Will Turner here, I'm requesting support for setup, as my computer skills are pathetic at best My contact: Thank you Date Time Of Last Edit: 2021-01-31 02:02:05
[2021-02-01 06:10:06] |
Looks like you have not even installed Sierra Chart. First step is to install it using this link: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe Can you at least do that and let us know when done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
