Date/Time: Sat, 22 Feb 2025 09:18:41 +0000
Not always copying all Drawings from a Source chart
View Count: 592
[2021-01-30 13:46:31]
DCSaba - Posts: 113
I have been here already: Copying Chart Drawings from Other Charts Automatically
BUT
On a TPO chart of mine some drawings do not always get copied form a source bar chart.
I have been trying everything on this list to solve this issue, but in the end I just recreated the not-copied drawings and that worked. But the fact is that some lines do get copied and some don't (be it trend line or horizontal ray). And sometime all copying works fine, until it doesn't.
Could you make some suggestions?
[2021-01-30 14:18:11]
Refer to:
Copying Chart Drawings from Other Charts Automatically: Copying Chart Drawings from TPO Profile Charts Not Supported (Copying Chart Drawings from TPO Profile Charts Not Supported)
Date Time Of Last Edit: 2021-01-30 14:18:24
[2021-01-30 14:43:15]
User912279 - Posts: 102
Thank you. I have referred to yourlink before, too.
Since my issue is not copying FROM a TPO profile, but the other way around: from a bar chart to a TPO, may I assume that this does not work either for similar reasons?
[2021-01-30 15:32:41]
Yes.
[2021-01-30 16:45:31]
Thank you. I understamd your reasoning and in fact never could make any sense of trendlines on my TPO.
I DO make full use of horizontal rays on my TPO that I share with Bar charts and these are the ones that mostly work, but sometimes they don't (as described above).
Today, my solution was just to recreate the horizontal lines that were not copied over and it worked.
Is it going to stay this way or should I expect that even these horizontal rays will stop working at some point?
Thank you
[2021-01-31 02:00:08]
These will not copy properly either.
Yes.
