Date/Time: Sat, 22 Feb 2025 09:41:59 +0000
[User Discussion] - Ask/bid difference text
View Count: 520
[2021-01-30 04:50:47]
User575399 - Posts: 326
I’m using a 5 tick aligned renko on one chart with the ask/bid volume difference above each bar.
The other chart is a 5 tick aligned renko number bar chart.
The ask/bid volume difference on each chart is different . Shouldn’t they be the same since they’re both 5 tick renko charts ?
Is their a way to get them to match ? Thanks
Date Time Of Last Edit: 2021-01-30 04:51:11
[2021-01-30 09:54:52]
There must be some difference between the chart bars. Refer to:
Working With Charts: Resolving Differences of Chart Bars Between Charts
[2021-01-30 18:15:57]
I checked all that and it is all good. I attached the 2 charts I am referring to . Let me know if Im missing something.
I’d like the delta text in chart #3 read the delta text like chart #21 if possible . Thank you
Date Time Of Last Edit: 2021-01-30 20:50:58
Private File
