Date/Time: Wed, 23 Sep 2026 17:39:07 +0000
mulitapale charts handeling
View Count: 943
| [2021-01-29 21:46:45] |
| User942196 - Posts: 40 |
dear friends all the time frames i am using for trading are located on the same window as multiple charts tabs at the buttom of my screen (see picture enclosed) i navigate them using the mouse but i would love to have a shortcut on my keyboard that would do that. is that posibble? can i toggle between tabs or designate a shortcut for that? Thanks M |
| [2021-01-29 22:34:03] |
| John - SC Support - Posts: 47988 |
There are options for Next Chart, Previous Chart, and Go To Chart Number. These are under the Window pulldown with default keyboard shortcuts of F4 and F9 (Next and Previous). Go To Chart Number does not have a default. Refer to the information starting here: Window, CB and CW Menus: Previous Chart (Window) You can customize the keyboard shortcuts for these using Customize Keyboard Shortcuts. Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-31 13:46:00] |
Great! that di dthe trick and another question - when i toggle between charts it does not remember the last position the chart was. it always moves the candels to the right even if i left it in the middle or thr right. can i make it stay wher i left it? M |
| [2021-02-01 15:13:58] |
We are not able to reproduce the situation you are describing, even using different options, including detached windows. For us, whenever the chart is scrolled back (so the current bar is not in view) and we change between charts, the charts are always displayed at the position that we last left it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-01 19:22:08] |
O.k So last Question i can't find nowhere the shortcut for moving between chartbook tabs do you know where it is? `Thanks..... (-: |
| [2021-02-01 21:08:09] |
Refer to the following: Window, CB and CW Menus: Previous Chartbook (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-02 02:39:27] |
Regarding post #3, refer to: Working With Charts: Charts Unexpectedly Scroll Back and Change Fill Space Amount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
