Date/Time: Fri, 02 Oct 2026 20:54:43 +0000
SC datafeed Quotes vs IB (change% not the same)
View Count: 851
| [2021-01-29 15:54:11] |
| User968625 - Posts: 260 |
Hello, I use IB for options trading (what I meanly do) but love SC for charting (and play with futures). however, I noticed that the quotes of %change in IB is different than SC data feed %Change. I contacted IB first to see if there was a setting (knowing that you are not fond of them) but there isn't. I am wondering why is that and how to make sure the %change I have on SC is right (the quote itself is identical) Thank you P.S - Pls don't make this about IB issues. this is a simple question about this % change |
| [2021-01-30 08:52:14] |
The percent change in Sierra Chart is not a field of data from Interactive Brokers. It is calculated. The formula is here: Getting Quotes: Field Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
