Date/Time: Sat, 22 Feb 2025 09:13:37 +0000
More volume on Sierra than on the CME website
View Count: 573
[2021-01-29 15:51:17]
User8900561 - Posts: 1
I believe I am seeing more volume on Sierra than on the CME website.
Sierra might be right and the website might have a time delay, that why I am wondering is there any way to confirm other than executing a trade?
*I have tried that [translated the symbols to current service], it doesn't seem to be sorting the issue, is there a way through sierra to confirm the data is correct?
*I don't think that my issue is a real-time issue, I have compared it to the internet and it looks different
[2021-01-29 16:02:01]
John - SC Support - Posts: 38116
Keep in mind that daily volume will differ from the intraday total volume. Refer to the information here:
Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume
If that does not answer your question, then we need to know what symbol and what time frame are you looking at.
[2021-01-29 19:53:35]
What is the symbol and where you seeing this volume value?
