Date/Time: Sat, 22 Feb 2025 09:18:20 +0000
Label Column on Chart?
View Count: 2445
[2021-01-29 15:41:04]
bwalks123 - Posts: 122
Is it possible to place a label column on a chart, either on the left or preferably the right side of the Price column? I know how to do this for the chart/trade DOM however, I can't seem to find the setting to do this for a normal chart. I use Volume Profile aligned to the right and set to always display last profile within view, my problem is when I have a bunch of levels I am tracking OHLC, Prev OHLC, POC, VWAP etc... these labels become quite intrusive and block large portions of my Volume Profile and I would like to set them in a separate column if possible.
[2021-01-29 15:55:03]
John - SC Support - Posts: 38116
The Label column is available for the Chart DOM just like it is for the Trade DOM. Just add that column in the Trade >> Customize Chart/Trade DOM Columns window. Refer to the information here:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
[2021-01-29 16:07:58]
I was actually referring to a normal chart, not the Chart DOM. I looked everywhere in settings and could not find this option. If this is not possible, is there a way to control the width of price value column so that longer labels sitting inside the price column would be completely visible and not cut off? Really appreciate the help!
[2021-01-29 16:13:44]
The Chart DOM is the DOM that is displayed on a regular Chart.
What you need to do is to turn on the Market Data Columns (if you do not want to trade from the chart), you will then see the additional columns on your chart. You can then customize them as you need.
Trade Menu: Show Market Data Columns (Trade menu)
