Date/Time: Sat, 22 Feb 2025 09:44:34 +0000
Multiple Instances of Trade Management by Study
View Count: 563
[2021-01-29 03:25:21]
User115740 - Posts: 12
I am having some great success getting my first Trade Management by study up and running and it is working 100% as expected. However, I would like to create several different trail by study options on the same chart and it seems to be that I will get a host of errors on my messages if I have them set up correctly but have the enabeled option turned to No unless I am using them. In addition, using the "button" the current walkthrough creates, turns them all on which unfortunately will disable the working trail as intended. So for example, I have a long trail off an EMA, if I wanted another option on the same chart, for a short trail on the EMA, the system seems to want to have either both on or none. Is there a way to make this work that I am not seeing? Thank you for your help!
[2021-01-29 13:36:39]
This will not be the case if you set the Detailed Logging Input with the study to No.
And for each instance of the study, set the "ACS Control Bar Button # for Enable/Disable" Input to a different number.
Date Time Of Last Edit: 2021-01-29 13:37:29
