Date/Time: Sat, 22 Feb 2025 09:14:43 +0000
Question about use 6E/6A chart to trade M6E/M6A
View Count: 696
[2021-01-29 01:24:46] |
User475690 - Posts: 34 |
Although I used Trade and Current Quote Symbol, but bid and ask of chart DOM doesn't display, and I don't know whether I have correct setting about price display format/real time or historical price multiplier could you give me instructions step by step ? |
[2021-01-29 03:55:05] |
With these symbols, you will need to set this setting to 1: Chart Settings: Trade and Current Quote Symbol Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Most importantly though update to the current version of Sierra Chart: Software Download: Fast Update And you may also want to enable this setting: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-29 03:55:24
