Date/Time: Sat, 12 Sep 2026 00:43:28 +0000
General Text Window
View Count: 815
| [2021-01-28 22:39:25] |
| SierraTraders - Posts: 69 |
In The Graphics Settings (General Text Window - Grid Colors) It changes the grid line colors in the "trade activity log" for all the top tabs (TA,Statistics,Trade,Period Stats,Chart Stats,Acc Stats) is there a way to set a default once selected changes/colors are applied.....? FYI: Each time reboot SC have to make changes to grid line in TAL |
| [2021-01-29 14:52:06] |
| John - SC Support - Posts: 47854 |
We just tested this and we do see some issues related to using and keeping the changes for the Trades and Chart Stats tabs, but for the other tabs it is properly keeping the changes when we exit and restart Sierra Chart. We will look into the issues with see with the Trades and Chart Stats. As to being able to save changes, yes, there is the ability to save the Global Graphics Settings. Refer to the information here: Graphics Settings: Saving and Loading Multiple Graphics Settings Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-30 11:16:46] |
We identified one problem with the color settings not immediately updating in the Trade Activity Log Chart Stats tab. We will fix this but there is no other issue. Once the grid line color is set, it does not change. Even on a restart. Sounds like you have some other issue going on. Maybe the main configuration file of Sierra Chart is read-only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-30 11:17:06
