Date/Time: Wed, 21 Oct 2026 08:40:36 +0000
[Locked] - Unfinished auction.business
View Count: 3832
[2021-01-28 19:49:42]
User266447 - Posts: 280
Dear Sir or Madam,
How can I put an indicator on a footprint chart witch will show levels with unfinished auctions?
I can attached a print screen if needed - I tried to do it straight away, but I am not sure you can see it.
Kind regards,
Arek
attachmentUnfinished_Auction.bmp - Attached On 2021-01-28 19:47:19 UTC - Size: 3.97 MB - 1570 views
[2021-01-28 20:13:29]
John - SC Support - Posts: 48279
Refer to the following Input:
Numbers Bars: Highlight Nonzero Bid&Ask Volume at High/Low
[2021-01-29 17:55:20]
Thank you for the link.
I put the indicator into a chart and I have squares at a footpring at the level where the auction is unfinished. However, how can I set the indicator to draw a line across a chart which shows the unfinished business until the level is reached again? Could take a look at the attachment - I put black arrows, so you will know what I am looking for.
Thank you in advance.
Kind regards,
Arek
attachmentUnfinished_Auction.bmp - Attached On 2021-01-29 17:54:58 UTC - Size: 3.97 MB - 842 views
[2021-01-29 17:59:49]
Please ignore my previous email. I have found it.
Kind regards,
Arek
