Date/Time: Sat, 22 Feb 2025 09:15:22 +0000
web trading panel - access
View Count: 513
[2021-01-28 11:59:28]
User563205 - Posts: 9
Please, can I get access also to web based trading panel?
I read here https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel
that: By default this web-based trading panel is enabled for all Sierra Chart accounts.
But my "account control panel" says that:
The feature is not enabled on the mondayblue Sierra Chart account. Not sure if it refers to web trading but adding this just for case.
Thanks.
[2021-01-28 12:17:21]
This is only supported with the Sierra Chart Order Routing Service or the Simulated Trading Service which you are not currently using.
