Date/Time: Sat, 22 Feb 2025 09:36:40 +0000
SC Data All Services symbol transaltion continuous contracts question
View Count: 413
[2021-01-28 06:44:32] |
onnb - Posts: 662 |
I have a chartbook that has continuous contracts I deleted all the data files from the data folder I then did Edit >> Translate Symbols to Current Service SC downloads the new data. In the data folder, I noticed that the current front month file has the new symbol like ESH21-CME But the folder dly files don't have the exchange, they appear like in the previous format ESH21 Is that expected? |
[2021-01-28 09:33:05] |
Yes.
